TwinTurbo.NET: Nissan 300ZX forum - Re: I went around last night and checked everything I could see
ttz'in (norcal)
on August 17, 2015 at 4:26 PM
posted by sputnikZ
on August 17, 2015 at 09:22 AM
Good seal on that left rear corner of exhaust VC can be frustrating first few times.
Harness issue you need to address.
Small ground from fuel rail to upper plenum on left rear attached ?
burning smell after plenum pull
sputnikZ
22:11:26 08/16/15
Ground wires connected? Any wires pinched? (n/m)
Hiram
22:55:05 08/16/15
Check your EGR tubes connecting to the plenum, I
YlwPrlZTT
00:41:04 08/17/15
sputnikZ
09:22:55 08/17/15
Re: I went around last night and checked everything I could see -
ttz'in (norcal)
16:26:48 08/17/15
That harness issue doesn't sound good. You should've have
YlwPrlZTT
18:36:19 08/17/15
small update but didn't have time to check smoke issue
sputnikZ
20:19:30 08/17/15
The injector is just a solenoid, all the ecu does is ground
YlwPrlZTT
20:55:01 08/17/15
Thanks for the advice! Time to go part shopping again.
sputnikZ
10:55:42 08/18/15
Here you go.
ttz'in (norcal)
14:49:44 08/18/15
Awesome find! No wrestling injectors from fuel rail! THX (n/m)
sputnikZ
15:25:23 08/18/15
Welcome.. (n/m)
ttz'in (norcal)
16:03:06 08/18/15
burning smell gone but remains a mystery
sputnikZ
12:37:58 08/19/15
Residue burn-off is common. Good choice on
ttz'in (norcal)
15:43:50 08/19/15
